- 2:20 PM
- Feb 5, 2016
- grafton wv
seems like the stihl clamp would be a better option
Why?Yeah, I think I am going to take it off and put a stihl clamp on it. No matter which way I go I dont get a warm and fuzzy about the intake setup on this saw....
For future reference......
Never un-snap that metal clamp. Just pop the whole thing off with a screwdriver. Put it back on by lining it up and wiggling it on. Again....never un-snap the clamp.
If you can cut the locking part of the clamp off, you can put a metal screw type clamp over the plastic part and tighten it up. This is doable without taking the jug off.This is what my 345 intake boot looks like with the plastic clamp on it. Looks like the bottom is pulled out a bit. Haven't been using it much until I can get a new clamp on it. Not really looking forward to taking the jug off just to replace the crappy plastic clamp.
I was thinking of that. But it is tight in there. My paws won't fit too well. Lol
I tried to move it back onto the jug with a long screw driver, but I can't get any leverage. I am not to keen with these clamshell jugs.
If you want to make up something to help the install and make it a lot slicker then something like this pair of converted pipe pliers helps out. You can grip at slightly different angles to give a "together and in" motion that allows the small tag to get into the slot. I made them after messing up the one in the pic and snapping a bit of it away !! after many failed attempts ...since then all installed worked 1st time . Sorry about the pics being a little fuzzyyou may be able to dremmel of those taps.This is what my 345 intake boot looks like with the plastic clamp on it. Looks like the bottom is pulled out a bit. Haven't been using it much until I can get a new clamp on it. Not really looking forward to taking the jug off just to replace the crappy plastic clamp.
different diameter on them versius 390 screw clamp thats why they still have different part number even both of them have got new parts number over the years.Or a 372 clamp?
