old guy
Love me some Husqvarna
- 2:58 PM
- Jan 21, 2016
- Becker Minnesota
The last few years I've picked up several 50cc saws with 18'' & 20'' bars & chains, most have been changed to 16''s. So what to do with the long bars?
I thought I would set up a 357xp to use them up. My 550xp came with a 20'' & a new .325 chain, I figure the 357 outta pull that no problem, but the smallest .325 rim available to fit 357 clutch is 9 pin which I have but the chain is too short to put that together.
So I pull the clutch & drum, rim & oil pump drive out of a 346, all this bolts rite on the 357, I bought an 8 pin rim & threw that on as this 357 should be strong enough to pull it. Today I was doing splitting and needed to noodle some gnarly stuff so out came the 357 & it worked really well, it seemed to put it rite on the power band, for a little while, then it seemed sluggish, the chain looked still sharp, then I noticed it was also dry, no oil.
Disassembly showed that the 346 drum bearing rurface was about 1/16'' shorter than the 357 drum, not allowing the splines to properly engage the oil pump. I bored out a washer to take up the space, we will see how that works.
