SOLD 3120 OEM Piston
Armbru84
Just trying to get by
1:15 AM
Michigan
3120 piston. Used. Has some small scratching on the intake skirt. Should buff out no problem. Other than that seems good. Has pin and clips
27 shipped
A2DEE0FB-9C4E-455B-BE6F-56AF8F976717.jpeg 46313BA5-564D-481D-A6E7-59B96E62390B.jpeg 29A2196E-E499-4B90-8CE9-3D017E5CEC96.jpeg 2EB6D2BC-3FB2-43F0-9829-9E922B00E9EC.jpeg A8018843-FE26-40D1-B792-4A5FD8C94431.jpeg
jacob j.
Lord of Cargo Pants
10:15 PM
Coastal Oregon
Does it use the same ring as an 084 OEM slug?
Depends on if you have an early or late 084 piston. The early 084 piston uses 1.5mm thick rings, which is what the 3120 pistons use.
The late 084 piston uses 1.2mm rings. The 3120 piston is also quite a bit taller than the 084/088/MS-880 pistons so you would
either need to cut the squish band in your 084 jug or turn the crown down on the 3120 slug.
Lightning Performance
1:15 AM
East of Philly
Pretty sure I have a late saw with the early air filter.
How much taller is it? I gota belt sander
Edit: thin ring here but it does not really matter
