298xp help
Fruecrue
certified hand catcher
3:02 PM
Alden NY
Buffers are shot.
Looks like someone was this deep once before and cracked the case trying to remove one.
Are these just push fit into the retaining holes?
Where's all the Husky guys at?
Fruecrue
3:02 PM
Alden NY
Just a little bit of crap behind the oil pump.
jacob j.
Only the weird
12:02 PM
Coastal Oregon
Buffers are shot.
They should be screw-in. Husky makes a specific wrench for those buffers and the back plate on them has slots for turning.
Fruecrue
3:02 PM
Alden NY
That's going to be a problem as most of the back plates are torn off.
Fruecrue
3:02 PM
Alden NY
Buffers came out fairly easily with needle nose pliers.
PTO side seal was torn all the way around.
Bearings, cases and crank in excellent condition.
Fuel tank is split right up the middle way up under the trigger. Don't think it can be saved.
I will take the trigger and associated parts out for further inspection, but for now, I'm going to watch some football.
Fruecrue
3:02 PM
Alden NY
Tank is kicked.
Split up the middle and across the top.
