kyle.kipple
Get busy living or get busy dyin...
A guy brought me his 288xp to work on. I tried to turn him away but he was persistent in having me work on it and said he wasn't in a rush. He bought it new several years back. Within the last 2 years he's had 4 different people workin on it. First time was for fuel system update. Received new lines and filters. Within 2 tanks the top end burnt up. The shop claimed he straight gased it but the owner ran 3 other saws with the same mix that day with no issues. The next shop installed new top end and redid the fuel lines. After that it Runs great for 30-40 minutes then won't hold idle, searching, revving a bit high then low then die. Third shop installed all new case,bearings, seals, oil pump...still same issues after 30-40 minutes. All parts was oem new.
I tore it down to inspect and noticed the throttle trigger was broke on one side causing slop and not allowing full throttle and a broke top AV mount. I replaced both and cleaned the carb. I just came back from testing it to see if I could experience the problem myself. 30 minutes I couldn't tune the L. In the cut she runs get and my tach shows 12,500 at WOT. Want some advice from others more experienced with these models. I believe once it gets nice and warm the seals are experiencing a small air leak. When the saw is hot and idling correctly if you tip it on its side the rpms drop noticeably. Any tips?
