288XP CRANKSHAFT HELP
ELECT6845
9:35 PM
INDIANA
Installing new bearing and crankshaft in a 288. The bad crank was a 501 81 49-01 replacing it with a 501 81 61-02 which is out of a 394. Suppose to work but the crank weights are hitting the bottom and locking the crank. Anyone know if there is a difference? Early model saws vs. late model saws?
ELECT6845
9:35 PM
INDIANA
Cases will go together but the crank will not turn. I even relieved the cases a small amount and it still is hitting.
jacob j.
Only the weird
6:35 PM
Coastal Oregon
I know some of the later 394 cranks have a line that runs down the middle of the crank throws that protrudes slightly. I'm not sure if it was by design or a casting issue.
I can send you a regular 288 crank.
sawracr
6:35 PM
Northern California
Sounds like bearings are binding, take a dead blow hammer and rap on both crank ends until crank frees up.
Mattyo
Youtube speciawist
9:35 PM
Farmington, CT
This is very interesting....never knew version 2 was that different.
