cus_deluxe
terms of service violator
- 6:36 PM
- Jan 3, 2016
- Michigan
intake at 67? btdc?
I checked squish 3 times but can’t hurt to check again. When I timed the saw when I first put it together I got
Exhaust 100
Transfers 116
Intake 67
That is with no base gasket. I don’t know enough about timing yet to know how much those numbers where they are would affect compression. I did think the exhaust may be a little high stock? I thought it would be somewhere around 105.
It has a schrader valve on the end of the threads a tube right up to the gauge that has pressure release on it.If your compression tester has an adapter on it, this can alter the reading in a small 2-stroke engine like a chainsaw.
Exhaust 100
Transfers 116
Intake 67
Timing numbers sound right. That 67 is from TDC.....right?
Is it compression tested?Is this a bad time/place to sell a Hiway 272 top end?![]()
Good summation.I’ll bet on port timing being messed up and bleeding off compression. Or maybe the chamber is too big. Oil in the cylinder with the compression test would be telling as to whether the problem is ring seal or not.
My opinion with the AM stuff is that you can’t trust it, so you have to have a real qualified guy like one of the porters on here go thru and check and correct it...but the quality/durability/longevity is also suspect, so it’s kinda like throwing good money after bad to pay a good guy to make it fly...the only way I see it making sense is maybe for a saw where OEM néw or used is NLA and the builder can verify that everything is correct (timing wheel, etc.) himself...?
Negative buyer bewareIs it compression tested?
We don't need no stinkin compression. If you don't believe me, ask PotMetalPony.
Probably a stupid question, but when you say from TDC is that the same as before top dead center? Don’t you time intake before top dead center or am I doing something wrong when timing?Timing numbers sound right. That 67 is from TDC.....right?
Before and after tdc will give the same reading. Easy way to tell your wheel is centeredProbably a stupid question, but when you say from TDC is that the same as before top dead center? Don’t you time intake before top dead center or am I doing something wrong when timing?
Odd. Most are wider in skirt. More thermal expansion in crown.Not according to Echo. The 590 piston is the same from top to bottom. Very tight tolerances compared to AM as to be expected.
What are you measuring with?45mm bore, 44.90mm top to bottom
