rfarr94
OPE Member
- 11:07 PM
- May 15, 2021
- Powhatan va
I put a Hyway 272 top end kit on a husqvarna 61. It came with a pop up piston and caber rings. I plugged the decomp hole. When I first built it I did a compression test and only came up with like 116 psi. Now I’ve got 1 tank of fuel through it and if I get the high screw where it seems right it will run ok but as soon as you lean on the saw at all the saw has no power and the chain just stops. Also it doesn’t want to start quite right. Even when warm it needs to have the choke on first. Did another compression test after one tank and still only 120 psi. Even after the piston breaks in I feel like I’m not going to get the compression. I would’ve thought compression should be 155 or better. What am I missing here?
