262xp rebuild for @hoskavarna raffle
paragonbuilder
6:29 AM
Norwich, CT
Ok I warmed her up and tried tuning her but she would idle ok then just die. In the cut sounded like too much advance, popping.
So I set the timing back to almost stock. Nada, somethings not right...
paragonbuilder
6:29 AM
Norwich, CT
Pulled the plug... Uh oh!!!
paragonbuilder
6:29 AM
Norwich, CT
It cleared ok cold but not warmed up.
Question is can I add a copper washer to the plug, or do I need to pop her open and grind a little out of the piston?
And what is the proper clearance to the electrode?
Tor R
Novice, Leg model #2
12:29 PM
Mandal
First I thought it was the hda87 i send to you, was one of the first rebuild I did....
I wouldnt grind the piston, there has to be other ways to fix the issue, you are probleby not the first one who goes through this
paragonbuilder
6:29 AM
Norwich, CT
No time to mess with this more... Need to get ready for the gtg!
But I'll try advancing the timing again, and look at the clutch brake this weekend at the gtg. Now we need to beat the hell out her and get her broken in.
It was 215 psi cold this morning. Definitely need a firm grip, but she pops quick.
Landmark
Chainsaw Hack
6:29 AM
WNC
Very Nice and looks strong.
paragonbuilder
6:29 AM
Norwich, CT
it look and sound very strong, I also loved the throttle respond.
I've followed your thread from day one, you have done one stunning job , beautiful porting!
Thanks! And thank you for the 87 carb! Marcello will be happy with this saw!
