2017 MMWS GTG Box Saw Build Off Rules
Fruecrue
certified hand catcher
12:46 AM
Alden NY
I sanded .012" off the base to get .020" squish with a gasket. Can always take another 4 off.
paragonbuilder
12:46 AM
Norwich, CT
If you are gonna go tight, you gotta make sure it's right. And that the squish band is true.
I'd sand the squish to true it up, then resand the base to set squish. If you are using solder, shave it down to just above the measurement you want. If you still feel the solder after a turn or 2 it's too big and not compressing to the true squish measurement and it's tighter than you think.
Fruecrue
12:46 AM
Alden NY
I have sanded the band a bit, with 220 grit, just to smooth and remove any imperfections.
It looks true. The solder I use is .024", can't even feel it after the first roll but I usually roll the crank 3-4 times.
I measured the band at both sides, front and back- all the same within .0005"
paragonbuilder
12:46 AM
Norwich, CT
That's perfect for .020.
I did one at .016 or so I thought...
I could still feel the solder after a bunch of turns, so I shaved the solder and rechecked it..
.011
12:46 AM
Hey, was just expressing my thoughts, but I'll live with the rules. As a few have stated, there are various ways they could have gone.
Hopefully I'll get a cylinder that has good #s + squish.
I'm sure I would be in way over my head in class 1, and class 2 would just be "forgetaboutit"! That said, I'm pretty sure I'll try to go without a base gasket no matter how they cylinder starts out.
X 66 stang347 X
12:46 AM
Georgia
There might be a good chance you'll get a good cylinder with a decent squish. I haven't checked this one but on 2 others I had a squish of .023 without a gasket and with a fairly flat band. But I did notice my band was plated this time and not on the others I had
twinstaged
12:46 AM
Ohio
On my first farmertec jug the base was .009" out of being perpendicular to the bore and it was corner to corner. One of those things that would be hard to correct without a lathe. At least they're cheap.
twinstaged
12:46 AM
Ohio
So what's the ruling on backpack nitrous bottles? I'm not competing, but it's been in the back of my head for a future build...
Definitive Dave
Piss Rev Mafia Member
12:46 AM
Central Ohio
for this competition it looks like nitrous is ok for class three but still aftermarket cylinder
twinstaged
12:46 AM
Ohio
Run any fuel in Class 3.......or oxidizers.
I guess what I mean is does the saw need to be all self contained or could a guy show up with a backpack nitrous tank, nitrogen tank, fuel tank as a self contained thing with a line running to the jet on his intake.
