20" .325 bar on a ported 2253 /550xp
NorthcentralYooper
3:32 AM
Upper michigan
Hi ,
I'm wondering if anyone has had experience with using this setup with a ported saw ? I realize it's a 50cc saw. Cutting 95 percent softwood and alot of limbing black spruce and Jack pine.
Thanks
rburg
2:32 AM
Tennessee
I have run the 20" .325 setup on a stock 50cc saw and it did fine. Currently my 350 has a 20" bar with a nk chain on it that I use to noodle with and cut wood that is likely to have some dirt in it. A ported saw would work well with the 20" b/c.
Ktoom
3:32 AM
Albany, NY
Right now, ive been running 20" 3/8's on my ported 2153 and it pulls it just fine. I like having that extra bit of reach when limbing.
NorthcentralYooper
3:32 AM
Upper michigan
That was my whole idea for the longer bar. All I got is birch , jack pine and black spruce. The black spruce and Jack I cut dead standing and burns great but wow the limbing is exhausting at times And I'm rarely cutting stuff over 12" dia.
NorthcentralYooper
3:32 AM
Upper michigan
Thanks for the input , I'll post my results here soon, it's been below zero last 3 mornings so no cutting yet
bikemike
2:32 AM
Cottage grove mn
I've seen many 325 on ported saws some very mean piss revin 026 saws and they held together nice
SawTroll
Information collector
9:32 AM
Troms, North Norway
I see no problem with this, except that the balance of the saw will be adversely affected. At least pick a 20" bar that is as light as possible.
Consider having a 16" bar as the standard setup, and use the 20" only when needed.
SawTroll
9:32 AM
Troms, North Norway
A 20" laminate bar balances pretty good on this size saw.
Not really, and it also depends on which laminated 20" bar it is about (no, I don't know which one is lightest - never looked closely into this). Nose size and profile does matter, but there are other factors as well, including actual length (78 - 81dl variation).
rburg
2:32 AM
Tennessee
Have you ever used a 20" laminate bar on one of these saws?
  • Like
Reactions: R2D
