2 Stroke theory in relation to chainsaws
junkman
Crush it
7:10 PM
pacific northwest
There is a lot of info on 2 strokes out there ,but most relates to bikes and sleds ,how much is transferable to saws when doing mods ?
Brush Ape
Direct Connection
9:10 PM
Metropolis, Il
The part about an engine working like an air pump. And the part that means you need fuel/air, compression and spark at an exact time while lubrication keeps metal parts isolated and incapable of increasing friction. A chainsaw needs a sharp chain might be one primary difference.
exSW
'Cause Thomas is a poopyhead
10:10 PM
United States
Doesn't a dirt bike operating over a broader rpm range than a saw make the biggest difference?
Nitroman
6:10 PM
Southwest Alaska
As long as you are referencing air-cooled engines, all of it, excepting the expansion chambers dirt bikes have.
skidooguy
Genuine smartass
8:10 PM
Wyoming
Bikes and sleds use exhaust power vales or variable power valves to help bottom end power is one of the major differences to me. I often scratch my head wondering how a tiny saw motor makes that kind of power.
10:10 PM
There's not nearly the same power to cc ratio in a saw compared to a bike or a sled. 60cc saw puts out 4 or 5 hp. 600cc sled puts out 120ish
Nitroman
6:10 PM
Southwest Alaska
Yes, but, if you take the saw motor, slap on a tuned pipe and a carb to match, she'll make the power. The tiny carbs are what kill power for a saw.
skidooguy
Genuine smartass
8:10 PM
Wyoming
I understand. It just seems so small I find it impressing. I am used to a 800cc Rotax so a saw motor just seems so small in relation. What are the new 600cc sleds claiming for horsepower these days just curious.
10:10 PM
I suppose it still is impressive if you look at how small a clamshell motor is (being fully self contained) and the power it puts out.
10:10 PM
Not sure. 500 indy in the early 90's was 87. So now it's 100. 600cc is prolly 120 to 130
skidooguy
Genuine smartass
8:10 PM
Wyoming
That's pretty awesome. My last 700 only had like 110 or so. My carbed 800 claims a little over 150 hp but who knows at my elevation.
Deets066
AKA Deetsey
10:10 PM
Bikes and sleds have way longer stroke, which changes a lot. Most of the tricks that work on bikes and sleds don't work for saws.
I would say throw out everything you know about bikes or sleds when it comes to modding a saw motor.
skidooguy
Genuine smartass
8:10 PM
Wyoming
That is a good question that got me thinking about it now junk man. Lol. Maybe I'll have to tear down my bike and saw next to each other.
skidooguy
Genuine smartass
8:10 PM
Wyoming
Right on deets I would love to dyno my turbo sled at elevation just to see what it's laying down.
exSW
10:10 PM
United States
Won't a bike and sled have different power curves because bikes are gear drive and sleds variable drive?
Nitroman
6:10 PM
Southwest Alaska
Ski-Doo 600 H.O. 130hp. Pol 800 running 180 as are AC and Ski-Don't. But these are computer motors where everything, even the oil pump are driven by comps. Carbed are down 135 hp for 800 Polaris.
If you read radio-controlled boats, a guy who wrote an article about his testing a 35cc motor with changing the pipes dimensions was getting around 12hp at near 20k rpm. So it is comparable.
Deets066
AKA Deetsey
10:10 PM
Try running 87 octane in a saw that has 200 psi comp and then a sled that has 200 psi comp and tell me how they compare.
jacob j.
Lord of Cargo Pants
7:10 PM
Coastal Oregon
Plus much longer intake tracts, larger mixing areas in the crankcase, longer rods on the crank, larger and longer transfer tunnels, etc. I've cut down a couple of older motorcycle pistons to use in saws but it was much more work than it was worth.
