2 power heads?
Four Paws
Chrome won't get you home
2:03 AM
ID
Curious if running two 60-70cc powerheads on a double ended bar would be a better strategy than running a single 90+cc powerhead?
At what bar length would you consider 2 power heads to be a benefit?
Obviously, oiling would be much improved.
Just got to thinking about this today and ask you what you thought.
bikemike
3:03 AM
Cottage grove mn
My guess. NO. They will never sync sure one could help the other out but I se no point in it. Some guy on YouTube has 2 huskys on one bar and didn't se any improvement in milling speed. Thought it looked like a waist of a good saw
DSS
widebody
5:03 AM
canuckistan
There's lots of guys running double ended bars on a mill
bikemike
3:03 AM
Cottage grove mn
If I had to run a big bar for milling and needed to think of using 2 power heads I'd rather get a old riding mower engine and use that cause of torque, noise, and fuel consumption. And save the powerheads for for your regular cutting. That's My 2 cents. But I'm the stupid guy that mills with a poulan 46cc
pud
5:03 PM
Albany Western Australia
Ive used two 395's on a 6 foot alaskan mill a fair few times and ended up hating it with a passion in the end , the good things were oiling twice as good , if would cut massive hard logs at pretty much walking speed and used to sound awesome at idle ! The biggest problem was trying to keep the revs under control i used full comp 3/8 chain on a gb 84 in double ender and two guys had to push almost as hard as u could or it just felt like they were gonna blow to pieces , ended up with the worst finish on slabs ive done and couldent stop the bar from flexing , also twice as much fumes and dust .
It maybe better with smaller powerheads and some on the other end that really knows what there doing but id never use it again
Glock37
4:03 AM
Monroeville Pa
The guy i repaired a 880 uses 2 on a 9 footbar Recently he just picked up 2 090 s to use
Wagnerwerks
4:03 AM
Pa
I just read a big thing on two saws not helping each other when used in tandem.... Not sure where it was. I was planning to run 2 42cc poulans...
sawfun
1:03 AM
Portland Oregon
I sold two 090g's and 56" & 66" double ended bars to a guy who Mills 50" - 60" oak & maple fairly often. He needed Chain Bar Repair to custom make a 10 foot bar for a monster stump. He uses a magnet to hold the center up until it is supported in the wood. I was covered a chance to see and make a video of this but was unable to get there. He has had no issue with double power heads but has a helper handle and auxiliary oiler setup as well for single unit cuts.
