1/4 in chain Advantages vs Disadvantages
Carhartt
11:13 PM
Central Pa
Customer of mine, tree service guy purchased a new Stihl pole saw and it came with 1/4 chain on it. He does not care for it and asked me to change it out. I don't have a lot of experience with 1/4 in chain. Advantages vs dis? Does Stihl put 1/4 on anything else new? He has a lot of 14 in 3/8 LP bars and chains from top handle saws and would like to match up with them.
I have some 1/4 stuff but it only came on 015's and maybe 1 other older saw (010?)
CR888
2:13 PM
Do him a favour & put a 3/8p polesaw sprocket on for him so he can use the chains he already has & keep things simple. 1/4" chain is beautiful chain, really, I mean really smooth which is nice on sub 30cc saws/power heads. Why its not so good is files are expensive, chain is expensive, cutters are tiny so you don't get many sharpenings before there worn away. I swapped mine over at the dealer for a 3/8 050 light bar and chain. 1/4" is good but its complicated.
Carhartt
11:13 PM
Central Pa
Was my plan exactly. I just didn't know why Stihl would do such a thing.
Willard
10:13 PM
Manitoba
You guys must be talking about Stihl's little 71PM .043 chain.
Better 1/4" chain is Stihl 23RMS .050 which I have carved with lots over the last 20 years. I've used alot of Oregon 25AP before that.
Only .050 chain that will rotate around a dime tip carver bar.
But trouble with pole saws they use .043 bars with the little 61PM 3/8 Picco or now the 71Picco 1/4"
Philbert
Chainsaw Enthusiast
10:13 PM
East Dakota
Small pitch, and narrow kerf chains use less force to cut with, so they are furnished with some low power saws, especially battery powered ones. Pole saws also have relatively small motors, and are usually used on smaller diameter limbs, so the 1/4" pitch provides a smoother cut, especially if you are pruning a live tree.
Negatives are what @CR888 noted.
I have narrow kerf, 3/8 low profile (Oregon Type 90) chain on my 40V Oregon pole saw and really like it.
We replaced the 1/4" chain on some STIHL HT133 pole saws with the 'Picco' chains so that they would all use the same loops. Word is that STIHL is going back to that chain, although, some will be available with the longer (14") bars.
Philbert
Willard
10:13 PM
Manitoba
I tried 71PM .250 .043 on my T536 LiXP but didn't like it as it can't clear chips in poplar and softwood to my liking. So went back to the Oregon 90 chain.
Did try the 13RMS .050 .250 with a carver bar but solid tip wastes alot of power and battery life.
Duane(Pa)
It's the chain...
11:13 PM
Centre County
I like quarter chain, but I’m probably in a minority. I have it on a pole saw and a rear handle 200. Tried it on a 241 too. I think it’s all semi chisel, but it lasts a good long time cutting in the sky on a pole saw.
Homemade
11:13 PM
Wisconsin
I had 1/4 on my 015. I like it better then 3/8lp. Way smoother. And on a plunge cut it isn’t so choppy.
CR888
2:13 PM
Some wood types 1/4 cuts much better with than others. I like the way NK 3/8 cuts too in 'some' cases it really shines. But for day to day facing any type of wood I think 3/8 050 works best generally. It too is not perfect, I'd like to see a Picco style .325, similar size cutters to 3/8lp but a few more of them closer together. At the end of the day you just want a pole saw chain to be smooth, not get pinched easily and acceptably perform.
dmb2613
11:13 PM
Randolph Virginia
The HT 250s come with 3/8 P chain on them, the smaller hp pole saws do much better with the 1/4 chain and that is why Stihl puts it on them
Lightning Performance
11:13 PM
East of Philly
I have used all of them on 101s
Hardwood 12" 043 3/8lp
Softwood is easier 12 or 14" mini 043. I did used a 16" mini once or twice in 050. 050 I'm told breaks drives. I never broke one. Tried 050lp 14" off my 200T. Slows the saw down.
Quarter inch sucks
CR888
2:13 PM
Its tough too put any rules down as it greatly depends on what you cut. A lot of the stringy bark gums I cut you want the widest kerf possible to avoid your bar getting pinched/stuck. PITA. I use 404 for any stringies once on the ground.
Philbert
Chainsaw Enthusiast
10:13 PM
East Dakota
Quarter inch sucks
Was running a HT133 a lot today with the 1/4" pitch: have to agree in this application.
Performance was poor. Chain life was limited. And a pain to sharpen (one guy even snapped one of the little files, even in a standard file holder).
Prefer the 3/8 low pro / 'Picco' chain.
Philbert
11:13 PM
I'm pretty sure I'm one of the few who remembers when Oregon made 1/4" round chisel in both full and skip .It didn't use a micro file but 5/32" .My old Poulan S-25 Da came with 1/4" .
Ralph Nader being Ralph Nader put the snubs on it because he said that type chain was only for professional use and saws that size were home owner types ,and it was gone in a couple of years .I can't really say it's faster or slower .For that matter I have several old small saws that still have 1/4" but none with chisel .They run but like many are shelf queens as I have a pair of Stihl MS200T's for that task .
