064 vs 066
8:39 AM
Thanks to your posts on the old fourm
I now know why people like these saws!!!
I really like them. I won't hardly pick up a 90cc saw now except to mill. I run a 34" on my 046 and that's enough. 7900 will do it but it doesn't have a wrap handle. It's going to be built for play soon any way
CR500
8:39 AM
Western NY
just won a wrap for mine this week off of ebay.
Brewz
12:39 AM
Hunter Valley - Australia
Anyone got any detailed info on the 066 red light swap to an unlimited coil?
I know it was discussed else where somewhere else but it got confusing
From memory I need to use either a dual key alloy flywheel or a polly flywheel.
The polly flywheel needs the bigger crank fitted, which needs a later model longer case fitted, so I might as well just get an MS660
I want to keep the red light with its original low volume short case so will the dual key alloy flywheel fit the small shaft crank that's in it now?
Brewz
12:39 AM
I also recall reading somewhere that the red light flywheel would work with the red light and unlimited coil, or was it the dual key flywheel would work with both coils?
I cant remember.
angelo c
Coal Member
8:39 AM
It must be horrible for a guy yer age to admit he's getting older.....;)
wait till you actually GET older....( I think that is around the time when you say..."i hardly use anything other then my ported 346/026")
8:39 AM
I really can't take the vibes of a 64/66 for long at all. The 46 or 7900 is strong enough I don't really notice a power loss with the 34".
angelo c
Coal Member
8:39 AM
I got an old "hacked up" 385xp you should run some day.....;)
pretty smooth for a light weight saw....( us ol guys can't swing the 90cc saws much anymore either....but I can still swing 85cc purty good when its ported right.. !!! ):pesas:
8:39 AM
That one did run. I t hi ink it's the best one I've done out of that series. I have 2 more in the pipeline now.
