064/056 mag11 build
jmssaws
Banneded
4:50 AM
The exhaust doesn't need to be low to run a long bar,my 064 is 98 and runs a 50" nicely
I'm afraid of the intake duration getting to big and killing case compression, exhaust at 96 needs more intake than I want to give.
Toad22t
4:50 AM
Central Wisconsin
I think we need to talk Adam into a shorter bar and raise the heck out of the ex. Besides, hes half way to a cant saw with no choke. Just got to drop the brake flag and it be on.
If this goes that way. Might as well get a head made with a pipe. I'm only planning on running a 28" max with a 11 pin. Lol
jmssaws
Banneded
4:50 AM
Just throwing this out there.....went out and looked at my notes...my 066/056 is 98* ex 120 trans and 79 on the intake 205lbs comp
I got another cylinder coming to check timing on and I'm betting the timing varies on them. These are very high from the factory.
I was guessing 100 122 76 on yours
This cylinder had 16 degrees stock give or take. I haven't raised them at all and have 17 degrees of blow down and it runs exactly like a saw that needs blow down.
I have cut 020 or 030 cat remember without my notes,I know there is skirt left but I'm thinking the plug will hit with much more
RI Chevy
5:50 AM
earth
Jason, where are you with compression at the present time?
