- 7:40 AM
- Dec 30, 2015
- Brewster, NY
I just used sockets to drive em down, just don't go too far.
This is exactly where some AM parts can help.The Stihl 044 and MS440 are/were surprisingly powerful for their weight, capable of pulling a 28" bar. They generated rave reviews.
A tree service company presented me with an MS440 last week in a complete mess. A climber used one 40' up for a large tree trunk section. He made the wedge cut too deep and the tree top grabbed the saw bar, pulled it away as it went down, and then landed atop the saw after a bounce. All the plastic housings are broken, the chain brake fused to the hot muffler, the outer handle is bent beyond recognition, the tank housing is twisted, and that may not be all that I find.
Get this: the engine still turns over, has 140 psi compression cold, and the spark is still good. So, I decided to rebuild it. Who knows, I may save the land fill from yet another dead chain saw that originally cost $850 new.
I built a simple case splitter from a spare piece of metal. Just drill two holes to align with the bar studs, and have the metal extend over the end of the crank. The bar stud nut furthest from the crank goes underneath, and the next one goes over. Adjust both to get the best angle.
Also purchased a cheap bearing puller from HF (don't know if you have them there). Works very well (MattyO) had demonstrated it.
If you clean that cylinder and get a new piston, a 10 mm can be a very strong saw. Making it a 12 will involve machining the case, etc. For a hybrid, I would choose to start with a 12 mm saw, or a Chinese knock off.
Here is my 10 mm in Red Oak (no port work, but gasket delete, timing advance, dp muff cover & HD-2 filter).
I love these kind of tales! And thumbs up to keeping these stihls runningThe Stihl 044 and MS440 are/were surprisingly powerful for their weight, capable of pulling a 28" bar. They generated rave reviews.
I love these kind of tales! And thumbs up to keeping these stihls running![]()
Yeah, you can feel a groove right there too, if I remember rightly........looks like the 460 hybrid project is on!!that jug is toast! worn thru the chrome on the inlet side. bin job.
You guys are sissy's, that is below where the rings are, she will run just fine!!!
Haha I'd run it!I see you've been hanging out with @T.Roller and me a lil much. Be careful. It's a slippery slope
And hey presto, the crankcases split, and wonder of wonders the bearings remain in the case so far.
Lastly threading up the 3 supplied M5s to fix the disc down was cool. I did clean and blow out the threaded holes in the casings.....after figuring out that we are reusing the engines crankcase fixing screws....but from the reverse direction of course...those STIHL engineers being the clever peeps that they are:
Fair enough, but apparently the special tools are also useful to replace the crank back into the casings.or you could do this
