- 11:21 PM
- Dec 30, 2015
- Brewster, NY
For removing cylinders a T handle T-27 and a plastic ring compressor are, IMO, a must. They are not expensive to buy.
Always lube the cylinder before inserting the piston, always flush the crank case with mix before assembly (to clean & lube), but make sure none of that lube in on the mating surfaces when you use the sealer.
Doing a piston for the first time is easier with two people, you will want 3 hands. Always make sure the piston is installed in the proper direction (the arrow on top faces the front).
