Redfin
Meh...
- 9:16 PM
- Dec 24, 2015
- Central Pa
My 194 likes a bit more pop off. Check your lever.
But that would just be stock timing.It's possible you installed the key backwards. If the key is on top of the crank, the filed portion should be to the rear of the saw
Yes, if he held the flywheel forward when he tightened it. I was thinking that if he installed the key backwards trying to advance it, he'd also turn the fw clockwise over the filed portion, which would retard itBut that would just be stock timing.
I thought about turning flywheel clockwise after I typed that.Yes, if he held the flywheel forward when he tightened it. I was thinking that if he installed the key backwards trying to advance it, he'd also turn the fw clockwise over the filed portion, which would retard it
That how i done it. Flywheel went counterclock wise.It's possible you installed the key backwards. If the key is on top of the crank, the filed portion should be to the rear of the saw
With it being a aftermarket carb it could easily be.Was thinking this morning. Could the meter levre be set a little high.
Wait.... what did you say! I can't hear you!
Just gonna leave this right here.Was thinking this morning. Could the meter levre be set a little high.
I wrote that before i read it.Just gonna leave this right here.![]()
Awesome. You should have a strong little saw now.Well i got the darn thing figired out. Got it out a bit a go and went to fire it up and pulled ot rite out my other hand. All the fuel ran into tje cylinder. Pulled the carb off pressure tested it and pissed out fast as it came in. The needle valve would not hold air even of i pushed it in. Pulled needle from stock carb and all good now. Fires up revs out good and idles perfect.
Through the needle in the old carb and for the heck of it thought id presure test it and the dam thing held pressure so who knows.
Anyhow thanks for all the help and advice.
