Clarkbug
Active OPE Member
- 8:59 PM
- Sep 19, 2022
- Northeast
Hey all.
So looking to try and get some confirmation on my troubleshooting approach for my 026.
I had posted on here a couple years back by now about how I needed to freshen it up since I had bought it with a carbon scored piston, but it had run great for me. Had the realization that was over 15 years ago now... Anyway, I had a couple soft maples to drop and thought I would give it a little run time. Dribbled a little gas in the carb and it fired right up and ran great. Used the saw over two days for felling and bucking, and no issues other than I could see a little smoke, but didnt think anything of it. Was finishing up the last cut which was a stumping cut, and the saw started out fine, then just bogged and quit. Checked the tank and was almost out of fuel, so thought that was the problem. Filled up, got it going, and the problem persisted. Would fire up, but then would die as soon as I went sideways. Let it sit, and then tried to make one more limbing cut, and it would start and die, or would run on choke for a second or two, but would die off fast idle.
All that said, Im guessing its either a fuel line/fuel filter issue, pulse line, or a bad seal. Is there anything else that I should be checking or look out for? I know the seals on these can be a real pain to deal with, so not looking forward to that part of things.
Appreciate any thoughts/input you can offer.
