RedGas
- 11:21 PM
- May 11, 2018
- East Virginia, USA
SPOIL SPORT!
So....I picked up 2 Craftsman 2.0 / 10" saws made by Poulan. Both run great but one has a bit more compression. Anyway I'm cleaning them both up and putting all the best parts on the best power plant for my keeper. I was going to sell the other but I decided with only $12 into each saw, I can sacrifice the lesser of the 2 to my little experiment. Ill be able to run lean ratios of the Saber with a load. It will have to wait till after the spine doc cuts me loose fully. Probably in March. Until then I'll pull the jug, check out its guts to make sure its worth testing. No bearing or scored part surprises ect. Ill take pics of the piston and cylinder for you peeps to scrutinize b4 I proceed with testing. Anyway, a question for those in the know on 2 strokes. If I pull the jug and end up trashing the base gasket, will doing a base gasket elimination using high temp rtv cause issue with a reed valve engine in a negative way? I know it often helps power on a piston port but no idea on the reed set up. I can also make a base gasket if need be.
Yes. Most like to see between .015 and .025 it seems depending on what one is shooting for?How many thousandths are we talking on squish.? Minimum? Use solder as a "plastigauge" then measure thickness.
I may have thinner solder. Came in a butane powered mini torch kit.
Seen engines run quite awhile without any oil under no load. What rpm is she spinning? Most are limited to pretty low rpm.Ok fellas. Round 2. Went right to 200:1. Saber and 90 rec fuel. Going for another gallon at wot no load. Tiller warming up right now.
[emoji106]Ill do this with a saw eventually in use.
I agree. See what she does buried in the dirt. I don't see it lasting long under a good load. I do enjoy the testing though so keep it going. I also want to see a rod hanging out of it lol.Without the load you aren't pushing heat into the piston, plus you don't have a lot of side loading on the piston. Just a bit of oil will provide the lubricity you need to keep from sticking the engine. I expect if you are running high revs that you will burn out the rod bearing before you seize it.
Skin still gets cold...helps with wind burn thoughIs that to be used as mix oil or am I to smear it on for wind protection? I've heard of the vasoline on the skin deal for cold. Not sure how much truth there is to it though.
The coating is worn off the land between the transfers, feels sand blasted.
