NorthcentralYooper
5:54 AM
Upper michigan
I use Amsoil dominator 50:1 , used to run Amsoil Saber 60:1 for years , many I know ran 80:1 for years as well. I think if your running a lean mix the extra octane keeps the heat down too .
Amsoil is huge up here in power sports it'd made in Superior, Wi so it's almost local.
Terence Hill
7:54 PM
I go by the manual.
From the Husqvarna 288xp manual:
33:1 Jaso FB rated oil. (I use FC )
NorthcentralYooper
5:54 AM
Upper michigan
I had a feller call me today that had been having bearing failures in 562XPs. Of course, I asked about oil. He said he was using a locally made oil that he mixed at 64:1.
Well I said, that's why your bearings are failing.....
Got to love the home brew oil , yea I know the full time fellers are always trying to save a dime. Was it synthetic or Dino oil?
Chief Cat Herder
4:54 AM
Synthetic, and popular with the locals.
It probably would be fine at that ratio in a stock saw, but the saws he was telling me about were ported, and had compression increases. He was looking to find a new saw builder, but after hearing about his failures, I was more interested in having him try a new oil instead of a new builder.
BTW, by name is Randy.......what is your name sir?
NorthcentralYooper
5:54 AM
Upper michigan
Hi Randy, That's not me ... I haven't had any failures yet knock on wood. My name is Jason
5:54 AM
What don't you like on the autotune ?
They mostly run too rich. Especially ported. Had a 576 that would 4 stroke with a 20" unless you run an 8 pin and pushed hard. The 550 was finicky on fuel and really needed 40:1 with a thinner oil than 800 or Belray for sure.
5:54 AM
im running 40:1 husky xp oil in 545 and 365. no problems here. the oil is free through from work.
Maxima K2 ran fine at 40:1. Some of the others made it sluggish at 32:1.
