Keith Gandy
Maxima K2 40:1 87 Pump Gas
- 9:55 AM
- Dec 30, 2015
- Provencal, Louisiana
Ive only used SaberDoes this include Dominator or only Saber?
Since I like saws I would have to unsubscribe to this if it was to change to trying to trash some.What we need is someone with a mill to conduct the same type testing I'm doing on cheap saws at lean ratios and post the results so we have that "side by side" comparison. I've never done this before so all the results are surprising and fascinating to me. Any takers on the trashing 6-10 saws on their mill for the good of the collective? I'm very interested in seeing the differences between oil performance in a heavily loaded saw vs what I'm doing. 9 hrs each ratio is kinda the base line. Bigger engines use more fuel so I'd think you will have to go hours to hours not gallon to gallon. Just a thought. Carry on gents. Enjoy your day.
Plus a lot more HP - rpms & torque. Same as a chainsaw can't duplicate the stress on oil, less HP, like a dirt bike.It’s pretty simple. Saws usually run at hotter temperatures and higher rpms. Loading a weedwacker is actually being easier on it than running it with no string. It will just carbon up faster. No string is like running a dull chain on a chainsaw. Speaking from experience here watching idiots blow up a weedwacker on a landscaping crew with 1” string sticking out. Lol
Yet an 8hp motor uses similar oil to an 800hp motor. Heat is still heatPlus a lot more HP - rpms & torque. Same as a chainsaw can't duplicate the stress on oil, less HP, like a dirt bike.
Does a piston/cylinder in a dirtbike vs a weedeater require different temperatures to produce galling? Im not sure?Yet an 8hp motor uses similar oil to an 800hp motor. Heat is still heat
How about a stock saw vs a ported saw? Do they require different oiling requirements?
I’ve seen 650* plus on cylinder fins on a saw after a milling cut. That’s the highest temp stick I had available to check it with and it melted instantly to liquid.
If I had time and a helper I’d consider torture testing some saws at higher ratios. The results would be skewed unless you clean the oil out of the case from running 20-32:1. Some 880s have died at 50:1 in short order from new milling so I wouldn’t expect some to last more than a cut at 100:1. An 8-10’ long cut with a 70cc saw in 18” wide wood takes about 45-60 seconds a foot to cut.
I wouldn’t think so. Aluminum needs to melt either way.Does a piston/cylinder in a dirtbike vs a weedeater require different temperatures to produce galling? Im not sure?
Good deal Ryan. [emoji106]
I just posed the question. I run saws, I don't fix them. Thus me asking.
