Keith Gandy
Maxima K2 40:1 87 Pump Gas
- 8:23 PM
- Dec 30, 2015
- Provencal, Louisiana
!! 1st is Mobil 1 at 40to1 in my 064/66 and the second is Red Armor at 40to1 in my 346xp1st. But what about both?
Ya the Mobil one was brown like that on the piston, exhaust, plug tooThank you Keith. That Mobil 1 looked like it is brownish.
The 2nd pic with RA oil, almost looked like a clear sheen on the piston.
I used that canam (or whatever it's called) stuff they had. It was so thick when it got cold. I could of cut it with a scissors.I figured. It's some brand I've never heard of. I'll get the name when I get home.
At 35°, it leaves strings in excess of 5' long when you're done pouring. Thins out in a few minutes of run time
Sounds like the same stuff. I didn't thin it yet, but 50/50 With fuel oil probably wouldn't hurtI used that canam (or whatever it's called) stuff they had. It was so thick when it got cold. I could of cut it with a scissors.
Had to thin it out some first.
I normally start at 3:1, a guy can always add more fuel oil.Sounds like the same stuff. I didn't thin it yet, but 50/50 With fuel oil probably wouldn't hurt
What would happen if you brought it up to 40:1?
No truer words have ever been spokenI don't know. I will repeat something that @tree monkey Scott has told me a few times.
He runs 32:1 because of the bearings. Those are what need the most oil.
