What do you weld with ?
backhoelover
SERVICE MANUAL MASTER
3:47 AM
lincolnton nc
What about Hobart no one spoke two words on them Junk? I'm looking to grab a flux core maybe even harbor freight to keep in my shop for service calls. I can weld sheet metal with stick but you better be right Working on combines and the like I'm not dumping grands into one what would you think could simply do the job
No harbor flux POS!!!!.
backhoelover
3:47 AM
lincolnton nc
Just bought a miller 190 was going to get the 211 but didn’t wish I would have. Now looking at a torch set
J & L Creations
Machine Design
2:47 AM
Texas
I own a Hobart beta mig 170, had allot wrong with it when I first got it used, but the guys that run the weld talk forum got me wiring schematics and control board schematics with all the components and values of them that I was able to repair all the problems and get it running like a dream again. I’m a happy camper now. Also the new HF Vulcan welders look impressive.
merc_man
merc_man
3:47 AM
southern ontario
That's where I would start.
Got some new wire after work and gave it a try. All good now. Ther was some brown dust crap ( rust dust?) that blew out the liner when i blew it out.
I could also see some rust looking residue on the spool once i got it off.
Red97
3:47 AM
MI
See if this is any better than the ln8 they discontinued...
Red97
3:47 AM
MI
Is that brandy new?
Didn't you have two other new to you ones that you got on the cheap?
Yep, brand new. This is the wire feeder.
Picked up 2 new to us power sources before this job.
Had 1 new feeder (old style ln8) that burnt up after 3k lbs of wire. Cobbled it back together has been fine the last 4k lbs of wire. But wanted a spare just in case.
My even hook it up to make sure it's good lol.
amberg
3:47 AM
Va.
Still like pictures. SA 200 ( gas )
AlfA01
10:47 AM
Evia, Greece
Just bought one of these Telwin MIG 210 Dual Synergic welders. Italian company with a pretty good reputation over here and in Australia.
It allows you to run on auto, where the machine does everything according to metal size and type. Supposed to weld from car body panels (.6mm) and up. Welds aluminum, steel and SS. So far I've only welded steel, but have a boat engine bracket job coming up and will run it on SS.
I also have a German Vector Welding CT 240 plasma, TIG and Arc.
Red97
3:47 AM
MI
We got the welders covered. Now where all the weld pics?
Dc600/ln8 pictured above running. .120" ns3m innershield wire
Currently set round 600-675 amps 38-42 volts
