Tuning on an echo 2511t
J. Dirt
7:43 PM
WNY
I’m sure there’s some of you guys that got these! 305D89D6-9C79-421E-A35E-DBB99F9BF924.jpeg I’ve had mine a little while now and have put some gas through it and warmed it up tonight to try and tune it a bit. It seems to hit a wall at 12,500 still sounding like it’s four stroking and according to the manual it’s between 12,2 and 13,3 for the high side.
I’m curious if anyone knows if it’s a limited coil? I do have the muffler gutted as well as the limiter caps pulled. I’m almost wondering if it just needs more run time with only half dozen tanks through.
J. Dirt
7:43 PM
WNY
Kind of thought so. I did run the H screw all the way in as well as almost all the way out and got no change in rpm. Might have to clean the carb?
chrissalas1
2:43 AM
Greece
I don't think so.The 2511 has about 2 years selling here in Greece so i have repaired about 6.The problem that customers tell me is that they have problem starting it.So far every i have tuned i richen a little bit the L screw and then everyone is happy.Brand new i cannot make them running more than 12600-12800.After a time you will be able to tune it more.Mine is about 1.5 years old and i have seen at the tach when i was tuning last month about 15000 rpm-but mine has more than 30 tanks on it.
7:43 PM
NW CT
They take quite a while to break in. Respond quite well to de-cat the muffler or bypassing the cat with a muffler mod. The 2511 and 355 both show excellent gains with minor port and polish. I tried bumping ignition timing on both series and never found much if any to be gained with timing change. Converting the 2511 over to 1/4 pitch bar and chain helps the little guy out quite a bit.
J. Dirt
7:43 PM
WNY
Since the last post I’ve gone to the Stihl 1/4” chain and run the saw a bunch. It’s definitely gaining rpms especially once it runs a while. I still think it needs more run time to get to full potential.
chipper1
7:43 PM
Grand Rapids Mi
Thanks for the update.
I need to get mine out and run it, it's still in the box I got it in.
I'm probably selling one of my ms201's and I'll probably get it out soon.
7:43 PM
I'm thinking of getting one of these. What chain comes with it? Stock.
J. Dirt
7:43 PM
WNY
Did some tuning today and she’s sitting around 13,8 after a good warm up. Tightened up the low and the high a little and it made all the difference.
7:43 PM
NW CT
These little saws take a VERY long time to break in. I tried playing with the timing and saw no discernible gains. The one I did and brought to Dan’s get together was used extensively the past few weeks. Definitely broken in now and is awesome! I have the sprockets and bars to swap over to 1/4” but the chain seems to be an odd drive link count. I am not setup to make 1/4” chain so I will have to play with it.
One thing I did notice is that once the ported was broke in the idle seems a little wonky. It’s not perfect (which I absolutely require for a climbing saw) it is still an excellent runner. I will have to throw a tach on it to get some final rpm numbers. They do like to be a little fat it seems. Regardless; I LOVE these little saws.
