Cerberus
Cerberus the aardvark, not the hell-hound!!
- 12:23 PM
- Jan 20, 2020
- Florida (tampa area)
Saw is 1.5yrs old but I do use it pretty hard (and as my default saw), it's a clone of a zenoah g2500 if it matters (the Scheppach version, has been a champ til this week)
First I found my idle was higher than it shoulda been...I do turn-up my Idle now&then before a climb if it's the type of thing I fear getting up there & saw not starting but am pretty good about turning it back (so maybe I upped the baseline Idle, or maybe it began taking-on air which'd change my kinda-fat carb settings to a faster, more optimal ratio by introducting air /eliminating the slightly-rich conditions I set for it)
I then tried tuning it...total nightmare. I cannot even keep it running (at any H&L settings) without keeping the Idle in a position where the chain's spinning (can put my tach on it if a reading would help, to me it was just "needing to have chain movement for the thing to stay alive, is no bueno/not a problem of carb-settings")
I "got it tuned" as good as I could but it still sucks, will stall out if I try revving in the first 30sec after a cold-start....it's super sensitive to carb changes or rather Low changes on the carb (H can be set in-cut normally enough), and has exhibited this weird behavior where I know it "can" rev&cut but could also "fall out"/stall, so I kinda "feather the trigger" to get it revving lightly for a second then start giving it more gas and it'll go fine (this will happen w/o changes to the carb, happens here&there with the saw as it stands right now)
Air manifold leak? The gap between the airbox housing and the powerhead itself (which is a pivoting gap on most top-handles I've ever seen) is no longer an even gap IE it's clear I've put force into the unit, but I noticed that gap nearly a year ago and it doesn't seem to have gotten worse...
Thanks for any insight on what to do, I have other top-handles but I love this lil guy it's my go-to saw I hardly notice it on my belt I don't want this guy on my bench any longer than necessary!
(*should note that the Off switch stopped functioning recently...I choke it to turn it off. Also about a month ago I swapped-back to eth-free, from canned fuels....this saw got canned fuel for most of this year. Air filter always kept clean and I use permatex to seal it so the intake manifold's insides are especially clean!)
