Jake Dykstra
- 1:12 AM
- Nov 25, 2018
- NW Washington
This is my nephews 026.
So I've replaced the fuel line and filter. Impulse line. Cleaned the carb real good see no issues with it.
Problem is it still wants to die when tipped forward. I assume fuel is puddling behind carb and causing a rich condition thus lowering idle speed and eventually it dies.
Turning saw left or right idle is constant.
I put the carb off my 026 on it and problem persist. Put carb back on my 026 and works great.
Sprayed break clean all around crank seals and base gasket and no change in idle.
Turned in L screw until it barely runs and it's a little better but still lowers rpm and wants to die.
Anybody have some great tips or tricks that are currently not in my cerebral arsenal I would love to here them.
Thanks
Thanks
