- 2:13 AM
- Jan 14, 2016
- North western Ohio
Concrete is made of Portland cement .One component of it is alumina from the blue clay used in the slurry .Alumina and aluminum are a couple of atomic numbers apart .What happens is you get a reaction and the concrete tries to eat the saw which it will over time .Another example is aluminum conduit buried to concrete,you cannot do it because it will disappear .Aluminum is what is called a sacrificing metal .It contact with cast iron,steel or copper it will cause electrolysis often called galvanic reaction . You can have something like a chainsaw left long enough on the concrete in a perfectly dry condition and eventually it will fall apart . Another example is an aluminum screen door contacting concrete,even a $250 one .It's painted on the outside but it will dissolve from the inside where it's not painted .I've replaced a few ,high dollar ones .The easiest thing to do to protect a saw is put it on a piece of lumber or a rubber ,plastic never in contact with a concrete floor for any length of time .Just my opinion
