dmb2613
- 5:55 AM
- May 13, 2018
- Randolph Virginia
I would also add, if you lie to me about the saw you are done no help as far as I am concerned
If the dealer checks the data on the control unit, he can see the settings for idle and high speed of the last run. If it is not within the green range, the cause has to be found.
The newer white solenoid valves are internally more resistant against fine dirt particles that go through it with the fuel. These fine dirt particles damaged the teflon sealing material of the older black valve (on the outlet). Then fuel leaked through even if the valve was closed. The white valve has a metal sealing plate and is therefore more dirt resistant. It can be used with the carburetors which had originally a black valve in it. (on the MS 261 C-M) Also it is importand to update the fuel filter to the newer orange one with finer filter material. There is a repair kit for that availible including the fuel filter and the white solenoid valve (1140 007 1802). After installation of the new parts a recalibration is nessessary.
Can't precisely answer question on age of fuel. Best approximation would be no more than 6 months. I have subsequently been using same fuel in a Husqvarna 435 without a problem.How old was the fuel? What does the piston look like?
Go by and take some pics.
Fish, Based on your questions I did some research. Found an excellent YouTube on interpreting piston scoring that may be of interest to others,How old was the fuel? What does the piston look like?
so you are saying his dealer is trying to stick one into him and being lazy then ?your warranty is good until 10-02-2019, I did not see where a claim has been filed
