- 3:04 PM
- Feb 4, 2017
- Winona County, MN
Now you’re thinkin “inside the box”!Take it apart,then it's a box of parts.
Now that is thinking outside the box.Take it apart,then it's a box of parts.
It might not be worth jumping through hoops to take it to a porter who doesn't seem to want to communicate with you. I don't know who you are wanting to get it ported by, but communication is very important.Now that is thinking outside the box.
To bad i cant get ahold of the builder or id jump through hoops to tear it down and box it up tomorrow for my flt on tue.
It
lots of more than capable members in this forum, I’d find someone else
If you are still bent on an adjustable, wj69 or 76 will bolt right on. Detach mtron harness from carb and tie it up in carb box. Will run with mtron coil.
How about a timing belt?I think your putting too much thought into a problem you don't have.
Nobody replaces the fuel pump in their car because it someday may quit working.
Run it until it gives you an issue, repair the issue and keep running it.
I don’t know whether it’s your intent or not but you are coming off as rather confrontational. You’ve gotten a lot of great advice here from regular members just looking to help out. You might want to think about tuning the aggression screw down a bit. Thanks in advance.Yes, im thinking of a fix for something that might or might not happen. is there something wrong with having some forethought (thinking ahead).
In case you didnt see it the first time in my previous post, i’ll repeat it. I will run what i have, except for upgrading to the newer solenoid and a better filter?
what is wrong upgrading to the most current replacement part for a part that stihl knows is prone to failure? I look at it similar to that of your fuel pump analogy, where the manufacturer puts a recall out on said fuel pump bc it is prone to failure.
If the solenoid is prone to failure, why not replace it before it happens?
@ElevatorGuy or @redline4 am i asking you to spend your money on my saw? NO, im spending MY money on MY saw. If y’all dont like it, not my problem.
Mayhaps he has an auto tune yap?I don’t know whether it’s your intent or not but you are coming off as rather confrontational. You’ve gotten a lot of great advice here from regular members just looking to help out. You might want to think about tuning the aggression screw down a bit. Thanks in advance.
If that’s the case the reset procedure is in orderMayhaps he has an auto tune yap?
Pics of moon rock hookers and blow?Dude, you need to chill out. I was simply asking a question as to the thought process as I personally dont see the point in replacing something just to replace it.
I could could give a chit less what you spend your money on be it moon rocks or hookers and blow.
M1,2 or M3? procedure is different.If that’s the case the reset procedure is in order
YesM1,2 or M3?
