Stihl M-Tronic Version 3.0
RI Chevy
1:35 AM
earth
Are the plugs getting smaller? What were the plug size?
1:35 AM
The 461 was never offered in M-Troinic because it is also the "Rescue Saw", and M-Tronic had problems with smoke.
Perhaps the new V-3s have addressed this problem?
Also, thanks for the clarification on what the ^ position is, I was confused on that also.
PogoInTheWoods
1:35 AM
Ohio
Normal is 14mm x 1.25 thread. I suspect we'll see a minor uprising when they introduce 10mm x 1.00 plugs here. Gonna seem cheap and frail to a lot of folks and will inevitably strip more easily. The upside is when they do strip out you can probably re-tap to 14mm just as easily as using a 10mm insert.
Would be time for new screnches, too.
RI Chevy
1:35 AM
earth
Thank you. [emoji106]
RI Chevy
1:35 AM
earth
Is there a thread on this knocking pin in/out? Or is it that simple?
Can it be reversed once it is knocked in/out?
I'd be interested in doing this to a few saws.
Stihl working Hard
Is it Friday yet
1:35 PM
Perth Australia
Yes it’s that simple,pretty sure I read somewhere it’s reversible if you remove the pump
RI Chevy
1:35 AM
earth
TY sir. I will investigate.
1:35 AM
Idk if it’s applicable to other stihl models but on 661 the pin is right next to the oiler screw. Take a punch or something else that’ll fit on it good and tap it flush and then you can have full adjustment range on the screw. It’s not a whole lot extra range but enough to put out a little more oil.
RI Chevy
1:35 AM
earth
Can't do it today, but I will check. And report back.
PogoInTheWoods
1:35 AM
Ohio
Not a typical option on most Stihl saws and not on all 661's either. It'll be obvious if it has the uprated oiler and the pin will be right there to see (and punch in). Bear in mind the oiler on max setting after punching in the pin will empty the oil tank in about a half tank of fuel..., at least according to the shop manual.
