Stihl 362 C-M scored piston
pwheel
Finis Origine Pendet
7:59 AM
MA
Question: If the MTronic or similar autotune system malfunctions with a lean mixture, how would you know it before the engine gets toasted?
Cobby08
I’m a face down ass up guy
7:59 AM
Central New Yawk...
Not 100% on your question but I assume you are asking if BOTH happen at the same time, it would be just like any other saw. It would probably lean seize/score. The MT/AT systems aren't really designed to compensate really for poor lubrication.
pwheel
7:59 AM
MA
I just wonder if a malfunctioning autotune system can lean-seize a saw regardless of oil/gas ratio.
Cobby08
7:59 AM
Central New Yawk...
I guess malfunction wise yes it could. I am not sure about the AT but I know the solenoid on the MT is a normally open solenoid so if there is a failure its just going to flood the chit out of it.
Ryan Browne
6:59 AM
Wisconsin
I bought my first "pro" saw a few months ago, a used MS362 carb version.
I buck with it, leaving it at 3/4 throttle or more for 5 mins or so, just moving down the hardwood logs and letting it self feed.
I may spend an hour like this.
I mix stihl orange bottle at 40:1 with non ethanol fuel.
This thread has me all worried.
I'm going to inspect the piston tonight.
I bought it to treat as a professional grade tool that would save me time.
This would really sour me on Stihl if I cant use it without worry of it getting damaged by normal use.
I'm with cobby08 on this one. Idle or WOT. No partial throttle.
7:59 AM
I guess that's another reason to dislike limited coils. If a guy listens for 4 stroking in between every few cuts, he's normally safe. Can't do so with a limited coil
Travis-Mc
OPE Member
6:59 AM
Wisconsin
I got the cylinder all cleaned up. It cleaned up nicely. I did hit the top of the chamber with the end of my mandrel, but I don't think it'll affect anything. You can see it in one of the pictures and in a reflection off the cylinder wall.
The squish with the new piston is about .010 without a gasket, .025 with the oem gasket, and .015 with a pop can gasket. I was hoping for .018", so I'm thinking of either making another gasket from some .008 aluminum, or cutting .008" from the piston to make a pop-up piston. Is it worth trying a pop-up for only .008" removed? I have a lathe and it would only take a few minutes.
Should I just use the OEM gasket? From my calculations, using an .008 gasket instead of the oem one will decrease the combustion chamber size by about 4-5%. Maybe I'm doing the math wrong, but I would expect about a 4-5% increase in compression, so 6-7 psi. Is it even worth it for that? Does a 4-5% increase in compression mean 4-5% more power?
Now if I do a pop-up piston I should get quite a bit more gain in compression, but I have no idea how much and don't want to do any more math.
Travis-Mc
OPE Member
6:59 AM
Wisconsin
That's exactly what I thinking. $5 for whole roll and I'll only need a few inches. I was going to lightly sand it to see if I could get it to .008"
But now I'm leaning toward running no gasket and doing the small pop-up. Not sure yet.
shadco
Ban Hammer Custodian
7:59 AM
City of Oaks, NC
Doesn’t cost much to try it with the stock gasket less risk too. You can always go thinner later.
Travis-Mc
OPE Member
6:59 AM
Wisconsin
Well that sounds like the safe thing to do, but where's the fun in that? :) I thought for sure you guys would say go for the pop-up, and you might as well port it a little while you're in there!
Once I have it back together, I doubt I'll take it apart again unless I have to.
I just got a 261 c-m, and would really like a 462 c-m instead of this saw, but I really don't need it, so I like the idea of trying to mod this saw a little so it doesn't just have .7 more hp than my small saw. But maybe you're right, use a stock gasket and a muffler mod that can easily be undone in case I decide to sell it. I'm on the fence.
