Stihl 029 super to 039 conversion
kkemp
11:47 AM
indiana
Well I tried a carb off my dad's 029 that runs good. My saw still didn't start . Took a compression test and it's only about 90 psi . So I'm pretty sure it ain't starting like that . What could cause that on a new cylinder?
11:47 AM
Broken ring possibly.
11:47 AM
I used cabers but you should have got decent compression with the supplied ones unless they were really bad.
kkemp
11:47 AM
indiana
I have some cabers to put in it now but I don't think the ones I had in it could've been that bad.
Fruecrue
certified hand catcher
11:47 AM
Alden NY
P&C new, rings looked fine and only 90 lbs. compression? Something doesn't add up. Spark plug threads stripped?
kkemp
11:47 AM
indiana
I checked everything on it . Wasn't leaking on the spark plug or decomp valve . Used the compression tester on other saws and it was right . .
Fruecrue
11:47 AM
Alden NY
This was that closed port 49mm cylinder? I've never seen that before, done more than a few of these (oem and am), always had 150 lbs minimum. Normally I see squish between 30 to 40 thou. Did you measure yours?
Fruecrue
11:47 AM
Alden NY
I keep looking back to the page 4 cylinder pics. Still blows my mind. Could be a port timing issue, but I doubt port height was changed when the engineer closed the ports. Was the cylinder dry?
On a side note I've always thought the rings would spread too far if I removed the support between the original style front and rear transfers, this new design says GFY to that school of thought.
kkemp
11:47 AM
indiana
Yep it's the closed port cylinder . But I completely forgot about measuring the squish . I put it back together now. I hope caber rings help . I'll measure the squish whenever I put the saw back together.
kkemp
11:47 AM
indiana
cylinder had a light coating of oil when I took it apart.
11:47 AM
I've bought new comp testers that were bad do you have another to try.
94BULLITT
11:47 AM
VA
Did you check the compression with the throttle open?
Sent from my SPH-L710 using Tapatalk
