kfd518
- 10:20 PM
- May 13, 2018
- Central Texas
Well got a bit of time to play today and came up with these.
Archer full comp square.
Something about these it is nearly impossible to stay out of the tie straps. Stihl rs with same settings doesn’t touch at all
View attachment 181574 View attachment 181575 View attachment 181576
Had the wheel at a knife edge almost before, was still catching them. Re shaping helped some not a lot though. It is what it is I guess
Not understanding lowering stone holder? Had arm tilted as far down as I could when I did those. Archer is definitely shorter.Lower your stone holder and come in at a more shallow angle to the chain. The archer chain may not be as tall as the other chain.
Thank you sir Makes sense now. I wasn’t seeing it in my head the angles I used on that funny enough barely nicked the ties in archer .325 chisel. But as you said chain was further up the radius.
I was really happy to see a blue wheel on it! I ordered a extra salmon wheel and the Multi-Point Diamond-Tipped Dresser.
I’m planning on learning with the salmon wheel.
How often do you dress it?All I use is the Salmon it’s easier to see the corner of the wheel into the tooth corner.
After one side of a 91 dl?
Just like mine. Chains cut good once you work out grinder.Man there’s no savings the box... I’m out of town for a few days, but hopefully by Friday I’ll get home and start playing.
