Philbert
Chainsaw Enthusiast
- 11:34 PM
- Jan 30, 2016
- East Dakota
When sharpening chain, the position of the file, relative to each tooth, determines the cutting angles. Many fixtures, jigs, and guides have been designed to help position the file accurately and consistently. The Vert-i-File takes a different approach: it positions the chain, relative to the person doing the sharpening, allowing them to guide the file horizontally, and to see the cutting surfaces as they are being filed.
This simple change improves the ergonomics of sharpening, by presenting the chain at a comfortable height, and eliminating the need to reach across, or around, the powerhead or the bar. It also eliminates common angle variations between Right and Left side cutters, since they are both filed in the same position.
The Vert-i-File positions the chain for filing, either mounted on the saw, or on the guide bar with an optional chain-tensioning accessory. It works with any pitch, gauge, brand, or sequence of chain, as long as a suitable guide bar is provided.
Once the chain is presented at the fixed, 30* angle, it’s still up to the user to position the file relative to the cutter top plate, create any ‘down angle’, define any ‘hook’, etc., allowing significant flexibility, and user preference. But, because the filed surface is on top, they can see the effect of each file stroke: it’s not hidden in the underside of the tooth.
The clean, simple design of the Vert-i-File is also appealing. Constructed of welded aluminum, it is compact (about 11-1/4" tall, and 4-1/2" front-to-back), light weight (about 12 ounces), and appears pretty durable.
For more info www.vert-i-file.de
r.lehmann@superscharfekette.de
Philbert
Philbert
