newguy#2
- 8:31 AM
- Aug 29, 2022
- right coast
So I bought a Husqvarna 562XP today and I'm having a minor issue with it.
I've got bar oil leaking all over, dripping out from under the clutch cover. I've installed & re-installed the bar a half-dozen times and it seems to have helped somewhat, but there is still an issue with oil 'leaking' instead of getting into the bar groove. The bar gets pretty warm during a one-minute test run, although there is finally a 'stripe' present that's flying off the bar. No visible oil from the groove appearing on the side of the bar near the tip though, unlike my other saws.
I finally got the saw to create an oil 'stripe' during acceleration, but there are still plenty of oil spots appearing and dripping from the clutch cover area. I'm wondering if the dealer supplied me with a 'non-compatible' bar so I've attached some pics for expert opinions. The bar is an HT-380 'Pro RSN' .050 gauge 3/8" 20"; it is not an 'X-Tough' bar and this bar is not listed in the online HVA compatibility chart for the 562XP. The bar's oil holes were inspected and found to be unrestricted, appearing normal & functional; they also 'line up' with the oil supply rubber boot. Chain is 3/8" C83 X-Cut. Did the dealer give me the wrong (or incompatible) bar? The saw was purchased new in a sealed box and the bar & chain were added to the 'basket' (saw assembled by me at home).
Thanks in advance for any opinions; hoping that I can move on with this setup and get some time in with this saw, it's running strong out of the box. If I have to get another bar I can do that also.
One last thing; the dealer attempted to supply me with an .058 gauge bar initially, but I requested the .050 gauge for the saw. Was that the source of this issue?
Moderator: I thought this thread was going to the Husqvarna section, my bad - move it if you get the chance! TIA
