- 6:42 PM
- May 30, 2016
- Ct
This modded 50mm OE hangs with the 7910 with the big bar. Surprised me. The b/c is the same other than being touched up a swipe or two. 7910 has the torque advantage for sure, it was running a 8 pin and the 372 a 7. As far as cut speed goes they are close considering the 7.8cc difference between them.I swapped this ported 7910 with 046 piston topend to another 6421 chassis. The bottom end it was on was going out (pto bearing play). I decided to do a little work to the jug/piston while it was apart. On first start it was sucking the choke shut on full throttle and I had to wind the spring tighter. After that I ran a 32” and 8 pin full comp in oak to stress test it.
