Saw video thread
4:21 AM
@huskyboy how do you like your 6100? One is on my very short list of saws to buy as soon as I sell my 034s.
Best I can sum it up is it was 95 degrees and no shade and a miserable day to cut wood yesterday. I cut from 8:30-3:00 and the 6100 did not let me down. No vapor locking sitting in 90 degree sun. Smooth, entertaining saw to run. Gonna run it some more today, another 90 degree day. The saw can work longer and harder than I can. Only negligible thing I noticed on it is the L screw seems to be fussy and don't like to be set fat. Mines about 3/4 turn out on L and seems to be getting better and better as I run it more.
Moparmyway
Its just a saw
4:21 AM
In a meeting
Seems like some with lightened pistons are better than others.
And, it seems, that some with heavier pistons, are worse.
288 piston in an 066 vibrates much worse than the stock piston does, (even if the stock piston saw has bad AV buffers)
4:21 AM
I noticed when I had my 365 closed port top end on my 372 it vibrated lot less than the big bore kit. A ported 365 topend going back on it, makes more power than the bb anyway.
4:21 AM
Al ... Re: ported saws ... I think it mostly just changes the frequency of the vibs, which some may like and some not.
A well balanced saw will vibrate less, but a single piston engine will never really be smooth.
Smoothest engines, in order, V-12, Straight 6, V-8. A 4 Cyl & V-6 typically need counter balancing shafts to make them seem smoother than they are. The V-6 is only common because it is easier to "package".
srcarr52
4:21 AM
Iowa City
Al ... Re: ported saws ... I think i mostly just changes the frequency of the vibs, which some may like and some not.
Opposed engines are the smoothest... no need for a counter balance on the crank. The only ones I can think of are the BMW motorcycle, VW and Porsche.
Single cylinders are by far the worst, you have to compromise the balance of the piston with the imbalance in the perpendicular direction that is created by the counterweight. Therefor most single cylinder engines are around 1/2 balanced.
4:21 AM
The downside of opposing engines (in addition to the added width) is keeping the pistons out of the oil (unless it is a dry sump). For those 2 reasons, V engines have always been more popular.
Heffalump
1:21 AM
NW Oregon
Mark running his Solo Twin...
.. and Dave trying to get a reading with his tachometer.
Those two plugs are so close to each other in the head that the reading pegs back and forth from about 3k to 6k. I should have hooked up the cable input.
Thanks for bringing it Mark!
X 66 stang347 X
4:21 AM
Georgia
Don't forget a flat 4 no counter balance. You Wanna run that mustang [emoji846]
X 66 stang347 X
4:21 AM
Georgia
Yes, the Subaru's are famous for oil consumption
True. Most of the engine failures is due to lack of oil. And the oil pickup cracking on the earlier models. But most want to use Mobil 1 and it sucks as a oil when it comes to consumption and protection.
Rotella 5w-40. 1/2qt between changes. That's with forged internals and 22psi.
TreeLife
I'm Dominick
4:21 AM
Berkshire County, Massachusetts
I use Rotella in some of my motorcycles, some folks laugh, some follow suit.
X 66 stang347 X
4:21 AM
Georgia
Messing with ya. Lol. your running a supercharger right? My Stangs down needing universal joints And rear tires again. I'm tired of nos so I'm going with boost. I'm back and forth on going with a supercharger or turbo which is going to change my whole setup.
