Chainsaw Jim
Con Artist LLC
- 11:55 PM
- Feb 8, 2016
- Springfield Oregon
Is that to reduce compression?[emoji13]
Look to be about 4* after primary side?Playing with epoxy.
288?
Playing with epoxy.
Nothing wrong with a little head.I like the head.
Nice work, exhaust port has good shapeI've got a little cleanup before I move forward. It is my first set of bridge ports. Cut .040 off the base and .045 from the band. A little epoxy on the floor of the intake and I ended up with
98/121/77. Squish is .021. This saw will be running a 36" bar primarily. Thanks @Mastermind and @Deets066 for posting the info, pics and discussion. View attachment 161921
View attachment 161922 View attachment 161924
Have to work tomorrow but I'll have "the rest of the story" in a day or two
Very nicely done Rich. I like the exhaust roof as well.I've got a little cleanup before I move forward. It is my first set of bridge ports. Cut .040 off the base and .045 from the band. A little epoxy on the floor of the intake and I ended up with
I’ve seen .017” difference from Mahle pistons to the new KS.For me, there is a huge difference in between opening up/reshaping a port and grinding a new passage in the cylinder. Lol I had to take a break and collect myself after the first bridge port. I did find it easier to use a diamond bit to "breach" the plating then switch back over to a carbide ball to finish. On a side note I've never put a degree wheel on my redlight. So I bolted up the redlight jug to the 660 I'm working on. I was expecting to see a bigger difference in the numbers. Digging through old posts here and over "there" someone mentioned there was a slight difference in the piston? That's news to me, I sure hope not. I just donated that original piston to a build a couple of weeks ago. Redlight jug was 95/121/81. original Stihl jug to the 660 was 93/122/82. This saw does have a Meteor piston on it but I dont think that makes a difference. Besides being a little heavier, the meteor always seem to be spot on.
I’d run it first to get a feel for it before I drilled anything.The 660 carb has a 64 jet. Will drilling it out to a 70 be enough? It should at least be a good place to start. Whatcha think?
