- 12:27 PM
- May 30, 2016
- Ct
@dall or anyone else who's converted a 394 to a 395 have you tried using the 394 carb? I converted wj71 to top external impulse along with using 7/32 bit to drill mount holes to fit plastic sleeves and attempted to use it but the throttle arm is too big and won't clear so I ended up using 395 wj115. The Venturi is much bigger on 394 carb. I thought about swapping throttle cable arms but rather not if there is a easier solution.
