scottspeed95
OPE Member
- 12:32 AM
- Feb 28, 2023
- Missouri
Hello again good folks. Had something I'm currently stumped on and needed advice / input on. I feel about as stupid as they come with this one.
Have a SP81 and a pro mac 700 that I just rebuilt the carbs on. Also did new fuel lines & filter too. Anyhow I have never found a SDC carb kit that comes with the carb base gasket (For the life of me I don't know why they don't include one!!!) so many times, I am making one out of carboard or reusing the old one. I had checked the gaskets and they appeared to be good. It may be a given to not reuse the gaskets, but I haven't really had issues before. Of course, if I have the gasket, I will use a new one but out of convenience I have done it a few times. It may be here to bite me in the ass now though..
The 700 part # is 86189 and 84081. I think that one of these is also used on the SP81 as it appeared to be the exact same gasket.
Anyhow is it common to see a leak here even if the gasket looks to be good? I would use motoseal but I didn't want to possibly block the hole for the impulse even though I'm fairly sure I could assemble it without having it slide and block the port.
Here's a short video. I may make another video to show it in action but I think you all get the gist of it all. Basically if you spray carb/brake cleaner anywhere around where the base of the carb is, the saw chuggs to a stall. Albeit the 700 is worse than the SP81. Takes more spray for the 81 to stall out.
Thank you so much everyone!!!!
