Dave Sr.
- 1:19 AM
- Apr 27, 2023
- Anamosa Iowa
A little more done on the log cutter. Drive shaft made have to weld on U joint yokes waiting for welding wire to be delivered, drive chain made to length need a new 50 pitch half link I have 2 of them but can't find the pins for them so chain is temporarily joined with a screw, ordered another 18 tooth 50 pitch sprocket to make a chain tentioner with. Next I have to weld the drive shaft and install the 2 U joints, make and install a throttle control air cylinder and adjustable throttle stop, chain guard and driveshaft guard and probably a few things that I have forgot. Should be ready to cut logs as soon as it dries up enough this spring
