fordf150
- 12:23 PM
- Jan 18, 2016
- Newcomerstown ,Ohio
didnt get pictures of the driveshaft but it worked out almost perfect. needed 103" shaft and spent a couple hours searching the junkyard for one that was just slightly longer so i could cut it down to fit instead of having to retube it but didnt have any luck with that plan. however I ran across a shaft that was 80" with the almost 50" of that being from the trans yoke to the u joint behind the carrier with the slip yoke being on the carrier side of the shaft, the idea hit me to use my original shaft and cut this down to fit between it and the trans. a couple conversion joints and cutting about 10" out of the junkyard shaft i ended up with my shaft. what was even better is that the carrier bearing ended up being only a couple inches past an existing cross member so it was easy enough to fab up a mount out of angle iron and weld it to the exist cross member. The downfall to all this......I have no idea what this shaft came out of originally so when it needs a carrier bearing it will get interesting
