- 7:00 AM
- Oct 18, 2016
- GFY
Yep I'm sure after school though lol.Now he needs a proper 2159 pic for his avatar
You bet!Yep I'm sure after school though lol.
Thanks man! I'm very happy with my 2159. In a few months I might port itWelcome to ope. You did a great job on your 2159.
Will be looking forward to the porting for sure. Have your dad set you up with a square chain as well.Thanks man! I'm very happy with my 2159. In a few months I might port it
Porting wasn’t in the contract for the cylinder...... sorry.... that’ll be another small fee. can’t wait to see it ported buddy!!!! Welcome to the forum!!!!!!Thanks man! I'm very happy with my 2159. In a few months I might port it
Thanks! But the porting won't be for a little while. Once I break in the saw and do some cutting THEN i'll port itPorting wasn’t in the contract for the cylinder...... sorry.... that’ll be another small fee. can’t wait to see it ported buddy!!!! Welcome to the forum!!!!!!
That’s what I was thinkingDang, tech class sure takes up a lot of the day! Lol!
The squatched 55 will spank it.Get that 2159 ported and see how she stacks up against your Dad's and my ported 357s!
(It will be closer than you think!)
The Squatch 55 better bring a lunch! Lol!The squatched 55 will spank it.
Ya knew that was coming. Lol!!
That squatch 55 got smacked down by a stock 254. LOL! You knew THAT was coming...ha ha!The squatched 55 will spank it.
Hmmmmm...I smell another shootout brewing.Ahhhh but I do have. 359 on the bench.... bwahahahahaha!
Once we ran out of things to install he wanted to check compression...it pumped up to 180psi WITH a base gasket! Out comes the solder to check squish. The band in this meteor cylinder is strange, squish at the outer most edge came in at .030, but the squish in toward the edge of the chamber is only .022. I’ve never seen a squish band that got tighter as it goes toward the center of the piston. Weird, hope it’s not indicative of a bad cylinder.
Check out the profile of the crushed solder
Squish at edge of cylinder
Squish at the edge of the combustion chamber, further toward the center of the piston. Backwards taper???
Austin @ZukiRyder400 great job on your first build and welcome to the OPE family!!! There is a little upgrade your Dad may have forgot about, you can use a 2255 clutch cover on your 2159 and have a better chain tensioner.
Ive seen that on a few AM cylinders. It’s not ideal. But it’ll run. You can fix it when you port it. [emoji6]
I sure did forget about that. We’ll get that upgrade done in the future. Thanks Joe!
I figured it wouldn’t be as good as a flat band. I know “a few” guys I could send it to for fixing when the time comes
