- 10:28 PM
- Dec 29, 2015
- Strong Island NY
This is @Jchin build. @RI Chevy , don’t be upset by this build.
Worksaw Build, again.
The basis of this build is using a 52mm Husky 272 Meteor piston. It’s a lighter, single thick ringed piston that’s lighter than an 046 Meteor piston. It’s approximately .100 taller though, so some machine work is needed. It allows finger/boost ports if needed at a later date because of its central ring pin design. No fingers on a hybrid though, it’s got enough area to transfer its case volume.
Here’s the 272 vs 046 piston. The 272 is lighter, has bigger windows, and takes up less case volume. Was gonna try a 288 piston in a BB460 AM head, but the 288 pistons weight was prohibitive, and that’s without the 13mm pin for which I have no lighter replacement.
272
288
046
272
288
046
