RedGas
- 10:47 PM
- May 11, 2018
- East Virginia, USA
Hey, all,
Somewhere I seem to recall hearing that by the time you wore out three chains, the bar should probably be worn out, or at least the sprocket tip. Is that true?
Reason I ask is, it seems like I go through more chains than that before the bars are wore out. I only file them to sharpen, and never rock them, and although we have a lot of sand around here, I generally keep them out of the dirt.
Maybe I'm filing them too much? Normally when I file, I file the tooth until it feels like the file is taking off meat from the entire "contact area" of the tooth. You can tell by how much the file "bites" or "drags." This generally takes between six and 10 strokes with the file. Also, I don't really try to use the same number of strokes on every tooth...I file until it feels right as said above. And I generally sharpen after every 4 tanks or so of mix, or sooner if I notice the chain getting dull.
I know it's hard to tell without seeing me do it, but does it sound like I'm taking too much meat off the teeth? Should I just concentrate on filing the cutting edges? (I use 13/64" files on 3/8" full chisel Stihl RS chains, mostly, if that matters.)
