Introducing myself
Vizionary
Active OPE Member
7:07 AM
Belgium
Hello all,
I posted my intro over here because i don't know where to place it.
My name is Thomas and i am 18 years old. I am planning to go on a course to become arborist in a year or 2-3.
I also try to repair saws if the problems with it are possible to solve. Because i don't have all the special tools that i need to do that kind of work. I will kick off my first post with a picture of my husqvarna 365 that i bought an hour ago as a project saw. Cylinder and piston are fine, but the covers etc need some work. Think i am gonna buy new ones for it.
P.M.P.
Stiff Member
1:07 AM
Michigan
Welcome is it a special model? or maybe a new xtorg version
Vizionary
Active OPE Member
7:07 AM
Belgium
I don't know yet, the original recoil starter isn't with it. There is one of the 371XP on it now. Can we tell that from the serial number if it is a special or normal?
Verstuurd vanaf mijn SM-G925F met Tapatalk
Vizionary
Active OPE Member
7:07 AM
Belgium
As you can see, the saw has been used very well. Things that i want to change first:
A original recoil starter.
A new muffler
After i want to repaint the crank case at the muffler side, And the clutch cover.
After that i want to replace the brake handle, the top cover and the airfiltercover.
Vizionary
Active OPE Member
7:07 AM
Belgium
I'd fix the broken screw and run the snot out of it
Yes want to try it but don't know how. i need a way to get that screw out without messing it up.
I'm not a fan of drilling in the muffler.
P.M.P.
Stiff Member
1:07 AM
Michigan
I could be wrong but I believe the early version 365 had the chain adjuster on the case in the front. The specials were on the cover.Also the 365 had a open port cylinder where the special has the closed port. The tag also has letters SP after the 365. There is alot you can do to that saw.
Vizionary
Active OPE Member
7:07 AM
Belgium
I could be wrong but I believe the early version 365 had the chain adjuster on the case in the front. The specials were on the cover.Also the 365 had a open port cylinder where the special has the closed port. There is alot you can do to that saw.
You are correct about that, it is a normal one.
bikemike
12:07 AM
Cottage grove mn
Good afternoon glad you could join us. Nice project saw you have there. Hope you enjoy your stay
Jimmy in NC
1:07 AM
North Carolina
Welcome! My first build was a 365. Its a slippery slope. It looks like a solid saw to start with. Wouldnt worry about paint and such, learn saw basics forst....as for the recoil, only difference is a sticker. Easy fix there...my spare recoil says 375K.
Welcome to a great message board.
Davey83
3:07 PM
Nsw Aus
My fathers 2000 model 365 special has an open port cylinder?
dennisguy
OPE Member
10:37 AM
Canada
Hey Thomas even I am new to this forum..
