Husqvarna 372xp
Keith Gandy
Maxima K2 40:1 87 Pump Gas
8:55 PM
Provencal, Louisiana
Im also wondering the differences between 2007 372xp, current 372xp, 372xpw? Any model yield better results after porting than the other?
9:55 PM
Most like the 50mm like you've got best. The least grinding any way. The xpw can be made to run as you know.
.035-040" plus a gasket delete gets you a good bump in compression and allows you to raise the exhaust and transfers back up.
Keith Gandy
8:55 PM
Sounds good. Ill go that route
9:55 PM
14-14.5 is pretty safe. I swapped from limited to unlimited on one and went from limiter to 15.6k with 4 stroking still. I would think 16.5k or real close is where the edge is for playing.
Keith Gandy
8:55 PM
Very nice saw Keith
Thanks Skippy. When ole John got it in when removed the muffler and the piston had machine marks and the crosshatch was still on cylinder walls. Appears to only maybe been cranked!! I told John I gotta have this ole girl!! Lol!!!
