I did a video a while back and has proven to be pretty accurate in terms of what needed to be replaced....and I suspect still is the case with the kits. I do know since I did my work on them , farmertec did a bunch of upgrades on the parts so this may be a little dated BUT here is what I had changed on the kits acquired 2015/16/17 ( I have not acquired one since 2017) , the ones that have survived a couple of years bucking logs on landings for a logger:
1) Bar Studs & Bar nuts! They are soft and will strip
2) Decomp to either a OEM Husqvarna or OEM Stihl
3) Handle Bars are real soft, changed them to Hyway from HLsupply. THOSE handle bars are pretty good.
4) Controls, throttle & choke..all three pieces to OEM.
5) Pull Start cords and those little plastic "dogs" to OEM
6) Spark Plug to NGK
7) Fuel Line to OEM
8) Pulse Line to OEM
9) chain adjuster shimmed
10) "o-rings"/ seals on fuel & bar oil caps.
I have not seen any issues with things like the case screws, plastic, cases, ignition, etc. I have had to tweak the throttle plates in the carb's, early on I would just swap to a used Walbro from a 066. Plastic.
On one I used a better crank, and a Hyway Popup piston in a Farmertec Cylinder, that saw is the best running one of the lot.
